MACsec.MKA.PortCnctChg
Description
Indicates connectivity provided by the controlled port. One of: 'PENDING' - Prevent connectivity by disabling the controlled port. 'UNAUTHENTICATED' - Provide unsecured connectivity, enabling the controlled port. 'AUTHENTICATED' - Provide unsecured connectivity but with authentication, enabling the controlled port. 'SECURE' - Provide secured connectivity, using Secure Association Keys(SAKs) provided by the MAC Security Key Agreement Entity(KaY) and enabling the controlled port when those keys are installed and in use.
Remedy
No action required - Notification message only.
Severity
Notice
Message Text
Controlled Port connectivity changed to %connect% on port %slotPort%.
Message Parameters
Name Type
connect String
slotPort SlotPort
Applicable Platforms
